8 years agoBuilding hex files fails - ext_flash
Hello Altera forums, I have a program based on the Simple Socket Server (RGMII), which I can compile and load to my SOPC with no problems. I'm trying to generate hex files so that I don't have ...
8 years agoHi,
Used Quartus 17.0 std and project from GitHub: https://github.com/samdejong86/arria-v-adc-ethernet Created a new project for eclipse with .sopcinfo file, And used .ccp files from the project given. I was not able to regenerate the error mentioned. It successfully able to generate mem_init_generate. Kindly compile the full project and create a new project in eclipse and check if still, you are facing the same problem you can use the latest version of the Quartus. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
