14 years agobuild uclinux-dist 20070130 make romfs microwin failed
I can find this post of hippo at link : http://hi.baidu.com/61led/blog/item/bf58210aa9a2443ae824887a.html i used uclinux-dist-20070130 and file pạtch uClinux-dist-20070130-nios2-02.diff.g...
14 years agoI don't have the solution to your problem, but if you make a mistake while modifying some files in the uClinux-dist folder and then get an error. The best solution is to remove this folder then take the original one from the 20070130.tar . Copy it into your nios2-linux folder and then do $ git pull in the copied folder.
The nios2-linux folder must be under home/yourname/ otherwise the git update can fail. Don't forget to create folder backup ! I hope it will help you !:)
