16 years agoBuild the Toolchain
Hello, I'm trying to build the Toolchain. I followed the instructions on web page: nioswiki->InstallNios2Linux At step: setarch i386 make gcc elf2flt gdb-host I get the following error. ...
16 years agoyou can learn more from http://www.nioswiki.com/installnios2linux.
you should pay attention to step carefully.when you begin to learn nios2,you should do just as the steps from nioswiki.or you will encounter many different problem.
