8 years agoBug in altera_16550_uart_init.c (altera_16550_uart_init function)
I had a problem with interrupt handling with the 16550 core. Presumably a programming error in the C code of the component: The uart did not process receive interrupts properly from the start. What follows is an exact copy of the nios code for the uart: altera_16550_uart_init.c line 439: /* enable interrupts at the device */regs = iord_altera_16550_uart_ier(sp->base);
regs |= altera_16550_uart_ier_erbfi_msk | altera_16550_uart_ier_etbei_msk;
iowr_altera_16550_uart_ier(base, sp->ctrl); } Should be: altera_16550_uart_init.c line 439:
sp->ctrl = iord_altera_16550_uart_ier(sp->base);
sp->ctrl |= altera_16550_uart_ier_erbfi_msk | altera_16550_uart_ier_etbei_msk;
iowr_altera_16550_uart_ier(base, sp->ctrl); } => reading the interrupt enable register, modifying the read contents and then writing the result back using a different value does not make sense. Best Regards, Johi.
