14 years agoBSP Generation Error
I am using NIOS for LCD and Key pad Control, recenlty am trying to interface SRAM for the nios code and have built a QSYS system for the same. when am trying to Re-generate the BSP in NIOS II i am ge...
14 years agoPerhaps the directory is read only. This line doesn't really make sense since the bsp-dir argument isn't set to something valid:
Error executing ' nios2-bsp-generate-files --bsp-dir--settings settings.bsp, unexpected return code 1 Have you tried using the command line instead? If you want to see an example go through the Qsys tutorial, there is a script there that builds the BSP and application.
