15 years agoBranch renaming in the linux-2.6 git repo on sopc.et.ntust.edu.tw
Hi all
The naming of the branches in our linux kernel git repository (git://sopc.et.ntust.edu.tw/git/linux-2.6.git) caused some confusion - especially along newbies - in the past. Walter Goossens suggested to rename our main development branch (unstable-nios2mmu) to something more convenient in [1]. [1] http://sopc.et.ntust.edu.tw/pipermail/nios2-dev/2011-september/005444.html I'm going to rename the unstable-nios2mmu branch to 'nios2' on sopc and my mirror at gitorious.org/linux-nios2/linux-nios2 if nobody has any objections. I'll also announce this in the forum. Additionally did a short writeup of the way we handle development for nios2 linux now and a short description of what every branch is about. I added this information to the Altera Wiki at [2]. Please enhance/expand if you see fit. [2] http://www.alterawiki.com/wiki/linux_sources Cheers Tobias3 Replies
Hi Tobias,
Being new to uCLinux (but not Linux in general) I have to say this renaming will help me a lot. I was getting quite confused by the various names :confused:. Could you kindly post a summary of the git commands that you would suggest in order to setup for the correct branch of uClinux-dist? Many thanks Vern - Altera_Forum
--- Quote Start --- Hi Tobias, Being new to uCLinux (but not Linux in general) I have to say this renaming will help me a lot. I was getting quite confused by the various names :confused:. Could you kindly post a summary of the git commands that you would suggest in order to setup for the correct branch of uClinux-dist? Many thanks Vern --- Quote End --- # git checkout -b nios2 origin/nios2 may work. - Altera_Forum
Many thanks, I'll give it a try.
Rgds Vern
