9 years agoBooting Nios from EPCQ-L does not work with Arria 10
Hi, our hardware is equipped with an EPCQ-L 256 connected to an Arria 10AX048 device (AS x4 mode). For storing the FPGA configuration data and the Nios2 firmware in the EPCQ-L I will use the Qu...
8 years agoHi Jon,
I found the solution with the Small Boot Copier Example from "Alternative Nios II Boot Methods" in AN-458: https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-alt-boot-methods.html I'm using the Small Boot Copier, it works fine with EPCQ-L256 and EPCQL-1024. The Default Boot Copier does not work with both. Jens
