9 years agoBooting Nios from EPCQ-L does not work with Arria 10
Hi, our hardware is equipped with an EPCQ-L 256 connected to an Arria 10AX048 device (AS x4 mode). For storing the FPGA configuration data and the Nios2 firmware in the EPCQ-L I will use the Qu...
9 years agoHi,
Check doc “Developing Nios II software” chapter “Boot Configuration Options” and check that you set correctly (bsp editor): hal.linker.allow_code_at_reset hal.linker.enable_alt_load hal.linker.enable_alt_load_copy_rwdata hal.linker.enable_alt_load_copy_exceptions hal.linker.enable_alt_load_copy_rodata Also check that you write nios code at the right addr. Default bootloader is looking for a .sof at addr_0 and the nios code must be placed just after this 1st sof. What is exactly your booting process? If you are using "booting from flash and running from onchip memory" I would suggest "Booting and Running From FPGA Memory", at least to test nios booting. Then you can init you onchip memory with an .hex file containing your Nios code. With this method you don't have to manage bootloaders or nios download from flash. Each .sof image you have on Flash has it own nios and you just have to select a sof file with remote update ip. hope it helps. Regards. ps: do you use Altera EPCS-L? I don't have any A10 board yet but I think I will try S25FS256S or equivalent for ASx4 script example for hex file:# convert nios from .elf to .hex echo "***************************************" echo "* .ELF to .HEX *" elf2hex --base=0x00 --end=0x3FFFFF --width=32 --little-endian-mem --no-zero-fill --input=project_name.elf --output=onchip.hex --verbose# copy .hex file to fpga folder echo "***************************************" echo "* CP *" cp onchip.hex ../../ cd ../..# update fpga programming files with new nios echo "***************************************" echo "* Update output files *" quartus_cdb BDFTOP -c BDF_TOP --update_mif quartus_asm --read_settings_files=off --write_settings_files=off BDFTOP -c BDF_TOP echo "* END *" echo "***************************************"
