8 years agoBooting Linux on MAX10 FPGA Development kit (ACDS v17.0)
Hello! I’m trying to run Linux kernel 4.9.76-ltsi-rt from altera opensources with buildroot 2017.11 on MAX10 FPGA Development kit with NIOS II, but it’s fail. I use this instruction (https://ro...
8 years agoHi,
--- Quote Start --- Did you get this to work? I too am having essentially the same problem. I modified the DTS to include the quadspi and also update the kernel cmdline With loglevel 7 set what I see is that the altera_quadspi is very unhappy when probed. >altera_quadspi 180014a0.quadspi: bank setup failed >altera_quadspi: probe of 180014a0.quadspi failed with error -22 --- Quote End --- Would you show me your DTS file? Regards, Kazu
