8 years agoBooting Linux on MAX10 FPGA Development kit (ACDS v17.0)
Hello! I’m trying to run Linux kernel 4.9.76-ltsi-rt from altera opensources with buildroot 2017.11 on MAX10 FPGA Development kit with NIOS II, but it’s fail. I use this instruction (https://ro...
8 years ago --- Quote Start --- To 0x00C00000 of CFI_512 Mb ? --- Quote End --- You're right. New kernel doesn't fit into region 0x0 - 0x00A00000. Rootfs is located in 0x00C00000 - 0x0360000. https://alteraforum.com/forum/attachment.php?attachmentid=15119&stc=1 Rootfs works if I check Initial RAM filesystem an RAM disk support in kernel config. The SPI flash does not work yet. I check SPI support and Altera SPI controller in kernel config, but it's still not work.
