14 years agobin2flash help
I am trying to program a binary file to epcs serial flash. However using the flash programmer, i get an error. The error message isn't very detailed, and just provides an error code. Does anyone k...
14 years agohi
1 - are u at nios2 command shell ? 2 - do you set the PATH to perl or perl5 ? i use elf2flash and i use elf2flash --base="yourbaseadd" --epcs --input="file" --boot="bootfile" --reset="cpureset" --output="outfile" good luck Franz Wagner
