15 years agoBeMicro: Cant download the .elf file on the board
I was trying to go through a tutorial called 'BeMicro Embedded System Lab Instructions'. But I am stuck at page 43 . The problem is to download the .elf file in the board. To do this I have to run...
15 years ago2 suggestions for trying to workaround this issue.
a). You're probably now in 'Nios II C/C++ (default)' perspective. You need to change to 'Nios II' perspective. Go to 'Window' --> 'Open Perspective' --> 'Other' and change to 'Nios II'. b). If this is not resolved, you need to run the Nios II SBT for Eclipse as with administrator privileges. On the Windows Start menu, point to all programs, point to altera, point to nios ii eds, right-click on nios ii software build tools for eclipse, and select run as administrator. Hope it helps.
