15 years agoBasic questions about FIFO, IRQs & DMA
Hello, i used a fifo from the megawizard library and introduced it into the SOPC system (just the DATA and the HALF_FULL signals the others signals are exported to outside the sopc system).
How can i write DATA to the fifo? I see there are wrreq and rdreq signals.(both outside my sopc system). How can i read the fifo from the DMA? And the last question is: I set the HALF_FULL signal as an IRQ, how can i program it in C using NIOS? Thanks a lot.2 Replies
My system looks like this (attached image)
And here is my code#include <stdio.h># include <stdlib.h># include <stddef.h># include <string.h> # include <system.h># include <io.h> # include <alt_types.h># include "sys/alt_dma.h"# include "sys/alt_cache.h"# include "sys/alt_alarm.h"# include "alt_types.h" static volatile int txrx_done = 0; int i; //callback function when DMA transfer done static void txrxDone(void * handle, void * data) { txrx_done = 1; } void initMEM(int base_addr,int len) { for ( i=0;i<len;i++) { IOWR_8DIRECT(base_addr,10,i); } } int main() { printf("testing ssram & sdram : dma operation\n"); alt_16 buffer; //memset((void *)SSRAM_0_BASE,0x7a,0x10);//this write base on byte initMEM(ONCHIP_MEMORY2_0_BASE,0x10); // memset((void *)(SDRAM_0_BASE),0x33,0x10); printf("content of ssram_0:before DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(DMA_0_READ_MASTER_MY_FIFO_BASE,i)); } printf("content of sdram_1:before DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(ONCHIP_MEMORY2_0_BASE,i)); } int rc; //request alt_dma_txchan txchan; alt_dma_rxchan rxchan; void* tx_data = (void*)DMA_0_READ_MASTER_MY_FIFO_BASE; /* pointer to data to send */ void* rx_buffer = (void*)(ONCHIP_MEMORY2_0_BASE); /* pointer to rx buffer */ /* Create the transmit channel */ if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open transmit channel\n"); exit (1); } /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open receive channel\n"); exit (1); } /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan, tx_data, 0x10, NULL, NULL)) < 0) { printf ("Failed to post transmit request, reason = %i\n", rc); //exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan, rx_buffer, 0x10, txrxDone, NULL)) < 0) { printf ("Failed to post read request, reason = %i\n", rc); //exit (1); } /* wait for transfer to complete */ while (!txrx_done); printf ("Transfer successful!\n"); printf("content of ssram_0:after DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(DMA_0_READ_MASTER_MY_FIFO_BASE,i)); } printf("content of sdram_1:after DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(ONCHIP_MEMORY2_0_BASE,i)); } return 0; } - Altera_Forum
Did you write an avalon wrapper for the FIFO?
