12 years agoAvalon-MM-Slave address alignment
Hi All I have aquestion regarding the address alignment of a an-MM slave. My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide. Now I'm trying to write the custom prip...
12 years agoIIRC the Nios won't generate burst transfers either (except maybe for cache line transfers).
So qsys will probably have added a burst adapter! Personally I'd just define the correct values and ignore the Altera definitions - they just confuse things. qsys will show a base address for your slave of (say) 0x123000, fix this rather than letting qsys assign the addresses. In your header file:#define MY_SLAVE_BASE 0x123000
struct {
volatile unsigned int reg_0;
} my_device registers;
extern struct my_device *my_device; In your source, and assuming you aren't using the MMU: struct my_device *my_device = (void *)(0x80000000 | MY_SLAVE_BASE); Then you can access my_device->reg_0 the same as any other variable. The fabric will convert the low address bits into byte enables for you. But note that the nios always does 32bit reads, char/short writes will assert the expected byte enables.
