14 years agoAvalon-MM Master reading
Hello, I am trying to run Avalon-MM master to read data from memory chip, so I've written a code accessible here: http://paste.org/41475 When I try to count data when readdatavalid is asserte...
14 years agoWell it's a simple state machine: avalon-mm read master. (http://paste.org/42242)
You can see the end_read state counting valid and invalid packets. Nothing fancy here, but this solution works. The data is read from SDRAM and moved to DCFIFO.
