14 years agoAvalon-MM Master reading
Hello, I am trying to run Avalon-MM master to read data from memory chip, so I've written a code accessible here: http://paste.org/41475 When I try to count data when readdatavalid is asserte...
14 years agoHard to tell what's going wrong here without seeing what is controlling the memory writing. The read statemachine looks safe to me so I wonder if your logic is issuing a read and write simultaneously since that could easily cause the readdatavalid to never return. I highly recommend you simulate your logic since that would make it really easy to find a simultaneous and other bugs.
I would also evaluate whether or not it would be easier to split your reading and writing into separate masters.
