15 years agoAssembly + Nios + two cores
hi, this is sundaram from University of Waterloo. I have a quick question. I have a design where there are two cores and they both have executable sections on the ddr2 sdram which, is connected throu...
15 years agoyou could try to light a LED in the software, the operation is simpler and less prone to problems.
Do the first CPU have access to the jtag uart? are you opening the nios console on the correct connection? You could run with a debugger step by step to check if the CPU does what you intended it to.
