20 years agoasemblle cope
Hi all!
I need to write an assemby code that will do some thing like this float callee(float a, float b1) { int c=7; return (b1-a)/c; } i know i could use nios-2-elf-objdump to produce assemblee code but when i do that , whenever there is use of floating point the assemblee code produce is call 0 <_ZSt17__verify_groupingPKcmRKSs> i have checked using the debugger and saw that code should be: 0x00805534 <_Z6calleeff>: addi sp,sp,-20 0x00805538 <_Z6calleeff+4>: stw ra,16(sp) 0x0080553c <_Z6calleeff+8>: stw fp,12(sp) 0x00805540 <_Z6calleeff+12>: mov fp,sp 0x00805544 <_Z6calleeff+16>: stw r4,0(fp) 0x00805548 <_Z6calleeff+20>: stw r5,4(fp) 0x0080554c <_Z6calleeff+24>: movi r2,7 0x00805550 <_Z6calleeff+28>: stw r2,8(fp) 0x00805554 <_Z6calleeff+32>: ldw r4,8(fp) 0x00805558 <_Z6calleeff+36>: call 0x876fa4 <__floatsisf> 0x0080555c <_Z6calleeff+40>: ldw r4,0(fp) 0x00805560 <_Z6calleeff+44>: mov r5,r2 0x00805564 <_Z6calleeff+48>: call 0x876d68 <__divsf3> 0x00805568 <_Z6calleeff+52>: ldw r4,4(fp) 0x0080556c <_Z6calleeff+56>: mov r5,r2 0x00805570 <_Z6calleeff+60>: call 0x876b3c <__subsf3> 0x00805574 <_Z6calleeff+64>: ldw ra,16(sp) 0x00805578 <_Z6calleeff+68>: ldw fp,12(sp) 0x0080557c <_Z6calleeff+72>: addi sp,sp,20 0x00805580 <_Z6calleeff+76>: ret How can i find how to refere to floating points command in assemblee?? How do i figure out where is the address of ,for example, <__divsf3>?? does this address get change from one compilation to another?? Thanks Ilan3 Replies
if you search the objectdump for __divsf3, you will find the address for the function. Yes, the address will change every time you change the source code. If you have a quick look to the code you posted, you will not save a lot by doing this in assembly, if you call the __divsf3 , __subsf3 and __floatsisf functions. Most of the work is done there. Stefaan - Altera_Forum
Try also to call the gcc with the -S option... it will produce assembler source code you can use as a starting point...
__divsf3 and the other functions called from the assembly code are contained inside the C library... bye Paolo - Altera_Forum
Thanks everybody!!
