9 years agoArria10 - Send linux command to the CPU through UART without minicom ?
Good morning,
I am using an ARRIA10 Dev kit board which Linux is installed in the SD card and I can access it by using Minicom. In the embedded linux, I have a small program I could use with parameters. From the computer connected to the board, I would like to run a command and read the result. (in a C/JS/Ruby program) for example: from my Ruby program located in my desktop computer, I'd like to send the `cat afile.txt` command in the embedded Linux and see the value of the file. I didn't find any clue, is it possible ? (I guess so otherwise it's should be pretty useless) Thank you very much.No RepliesBe the first to reply
