PHJ
7 years agoArria 10 HPS I/O Pin Multiplexing configuration
The A10 HPS technical reference manual has the following note for each of the pinmux configuration registers (e.g. pinmux_uart0_usefpga) : "NOTE: These registers should not be modified after IO con...
a_x_h_75
Contributor
7 years agoThat's correct. Changing the HPS I/O configuration away from that of the FPGA image will cause issues.
Cheers,
Alex
