8 years agoArria 10 fPLL lock problem
Hi all, I have a design that uses the fPLL in Core mode (transceivers are not used) to generate some clocks, the problem is that it never finishes the calibration, pll_cal_busy stays high; ...
8 years agoHi,
Apologies for the late response. Calibration is not required. I have checked with Reference clock frequency of 40MHz and output clock frequency of 24MHz. Also checked with Reference clock frequency of 150MHz and output clock frequency of 50MHz The pll_cal_busy signal goes low after 580 ns and pll_locked is asserted. Also, check below link may be it helps. https://www.alteraforum.com/forum/showthread.php?t=55008 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
