8 years agoArria 10 fPLL lock problem
Hi all, I have a design that uses the fPLL in Core mode (transceivers are not used) to generate some clocks, the problem is that it never finishes the calibration, pll_cal_busy stays high; ...
8 years agoHi,
Thank you for the reply. Adding a reset didn't solve the problem; I disabled the fPLL reset-calibration link with: set_global_assignment -name VERILOG_MACRO "ALTERA_XCVR_A10_DISABLE_RESET_CONNECTED_TO_CAL_BUSY=1" and now the PLL locks. pll_cal_busy was keeping the PLL in reset. pll_cal_busy is still active so the question remains: Do I need the calibration for the fPLL to work correctly in "Direct" mode? Best regards, Jakab
