8 years agoArria 10 EPCQL Controller
Hi, I am trying to program my EPCQ-512L from the HPS running Linux. I have the Altera Serial Flash Controller connected from its avl_csr and avl_mem connected to the HPS using the hps2fpga ligh...
8 years agoHere is a copy pasta of the code from the NIOS driver:
/* calculate current sector/block number */
sector_number = (block_offset/(epcq_flash_info->sector_size));
/* sector value should occupy bits 23:8 */
mem_op_value = (sector_number << 8) & ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_VALUE_MASK;
/* write enable command */
mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_WRITE_ENABLE_CMD;
/* write sector erase command to EPCQ_MEM_OP register to erase sector "sector_number" */
IOWR_ALTERA_EPCQ_CONTROLLER2_MEM_OP(epcq_flash_info->csr_base, mem_op_value);
/* sector erase commands 0b10 occupies lower 2 bits */
mem_op_value |= ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_ERASE_CMD;
/* check whether erase triggered a illegal erase interrupt */
if((IORD_ALTERA_EPCQ_CONTROLLER2_ISR(epcq_flash_info->csr_base) &
ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_ERASE_MASK) ==
ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_ERASE_ACTIVE)
/* clear register */
/* EPCQ_ISR access is write one to clear (W1C) */
IOWR_ALTERA_EPCQ_CONTROLLER2_ISR(epcq_flash_info->csr_base,
ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_ERASE_MASK );
return -EIO; /* erase failed, sector might be protected */
} I am not sure what type of example you're looking for though...
