8 years agoArria 10 EPCQL Controller
Hi, I am trying to program my EPCQ-512L from the HPS running Linux. I have the Altera Serial Flash Controller connected from its avl_csr and avl_mem connected to the HPS using the hps2fpga ligh...
8 years agoHi
I'm actually confronting the same problem. I'm using NIOS to write to EPCQL256 using asmi2. Can you be more specific - which bit?? can you pinpoint me in the bsp code?? I'm trying to write to FLASH_MEM_OP to bit 0 and 1. did you set a chip select. I will be appreciate to any help
