11 years agoArm DS5 debugger Issue
I am trying to load a hello world program directly into the on chip RAM of the altera Cyclone 5 sockit. The first time I did this some time ago, I did not seem to have an issue. However, since then e...
8 years agoI get this message sometimes when the CPU crashes. It can mean that the debugger can't contact the CPU. Did you try to reset and/or to power cycle your board? Are you sure its working correctly and that the HPS gets a valid clock input? Did you install a preloader and does it run? Did you check the boot_sel, clk_sel and HPS reset pins?
