22 years agoAPEX Nios Dev kit
[list][*]The factory default demo doesn't work at all. [*]When I download the new Nios project to Apex, It doesn't work ,either. But the project can work properly in another same dev k...
22 years agoTo Kerri:
I'm a Newbie. And the board doesn't work in my hands after I obtained the board, maybe someone in my Lab made a mistake to the board. 1. in the <nios 2.0> kit, I finds standard_32_devboard.flash (552 KB (565,257 Byte)) standard_32.sof (238 KB (243,757 Byte)) but it doesn't work. I wonder whether the following files are created by yourself ? recovery_configuration_apex_20k200.sof default_board_image_apex_20k200.flash Would you like to send these files to me ( [email protected] -----Max. 8M attachment ) and " ns " is not a command !!! Download *.sof by Byteblaster??? 2. http://www.altera.com/literature/ds/ds_nio...pex_20k200e.pdf (http://www.altera.com/literature/ds/ds_nio...pex_20k200e.pdf) P15 Table 2. Flash Memory Allocation : 0x100000-0x17FFFF(512KBytes) Nios instruction and nonvolatile data space. How do the Nios fetch the instruction in the flash? How can I find more detail about the flash allocaton? 3. Kerri, do you do experiments in the Apex Board wiht Quartus 1.1 and Nios 1.0? Is it wise enough to buy a latest Cyclone(Stratix) Nios II dev. kit , as I finds more information is based on these kits. Or I get the Nios II + Nios II IDE CDs and begin to applicate them in the Apex.
