22 years agoAPEX Nios Dev kit
[list][*]The factory default demo doesn't work at all. [*]When I download the new Nios project to Apex, It doesn't work ,either. But the project can work properly in another same dev k...
22 years agoThat's because the 16 bit and 32 bit run out of different memory.
Did you follow the instructions in the board manual? OK, From memory, open an sdk shell. typens recovery_configuration_apex_20k200.sof after it has downloaded... type nr default_board_image_apex_20k200.flash Then unplug and re-plug your board. (powercycle it).THen all should be well. You should also be on a later version of Quartus AND Nios! Nios 2.0 still had no problems with the Apex design, but Nios and Quartus are numbered differently. If you look in the readme.txt you will see what version of Quartus your Nios kit was tested with. Kerri
