22 years agoAPEX Nios Dev kit
[list][*]The factory default demo doesn't work at all. [*]When I download the new Nios project to Apex, It doesn't work ,either. But the project can work properly in another same dev k...
22 years agoWhat release are you using?
I'm also confused. At the end of your post it says that Apex is working, while at the beginning it says that the factory default is not working. Should I take this as the factory default does not work, but another design does? Please note that we use the factory default image frequently for APex, there are no known issues. But maybe if you tell me what you're doing step by step I can figure out where you went wrong.
