9 years agoAN458 Alternative Nios II Boot Methods doesn't work with Quartus Lite toolsuite
Hi
I would like to share what I have experienced with AN458. It used to work with the older Quartus versions, but since Quartus Lite it doesn't work any more. I don't know the exact reason but make_flash_image_script.sh file must be modified: this code section must be commented: conv -d $fake_copier ; # check for errors # if [ $? -ne 0 ] ; then echo "" echo "error: trying to convert the file $fake_copier to dos format." echo "" echo "deleting file $fake_copier, and $tmp0_outfile_elf and exiting!" echo "" rm -f $fake_copier; rm -f $tmp0_outfile_elf; exit 1; fi it used to transform the LF (Line Feed) into CR LF (Carriage Return + Line Feed)No RepliesBe the first to reply
