Although Unofficially Supported, how to get EDS on Ubuntu running
- 7 years ago
Hi James,
First of all, thanks for continuing using Intel product for more than 2 decades and that this is astonishing . From your description, it seems like we got to deal with a lot more compilers & dependencies that need to be fix first in order to get the EDS up and run on Ubuntu18.X.
There are pros & cons using latest Linux Operating System where we might need to deal with upgrade/downgrade the Linux Operating Environment set in order to make it works.
We understand your concerned about the old EDS version support but there is a series of consideration from marketing, resources availability, demand, stability, maintaining & etc perspective need to taken care off.
However, the alternative recommendation provided by JOHI earlier was something worth to be consider or as what you mentioned -Yeah - Go for Windows where we have more users and resources to cover this.
Here is the official communication about EDS across different OS'es for your perusal:
Operating System Support:
EDS Features & Availability:
https://www.intel.com/content/www/us/en/software/programmable/soc-eds/getting-started.html
So, based on the OS support table, we have both NIOS II EDS (Pro & Standard) supported on Windows. We will bring your input about old EDS version support on Linux back to our PSG-FPGA Division but there is no guarantee at all for enable this features in near future.
I hope you can understand this and wish to see you in others thread.
Joseph
Intel Customer Support
Perhaps another alternative here when running something like Ubuntu / Mint (or MX-Linux) is to simply use CentOS 6 in a VM to enable a complete solution under Linux. Running the Nios II EDS on CentOS VM should "work" as outlined in the officially supported systems from the documentation as equivalent to RHEL6. James
