15 years agoaltera 11 usbblaster ubuntu 11.04
Hello all, I am running into the dreaded ubuntu usbblaster issue. I am on ubuntu 11.04 32 bits with Altera 11 (which is supposed to be better). I got this to work using altera 10 with earlier u...
15 years agoSo in summary, I can program the device with the reference design, but somehow I am unable to download software.
$ nios2-configure-sof niosii_ethernet_standard_3c25.sof Searching for SOF file: in . niosii_ethernet_standard_3c25.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;./niosii_ethernet_standard_3c25.sof Info: Using programming cable "USB-Blaster [2-4]" Info: Using programming file ./niosii_ethernet_standard_3c25.sof with checksum 0x00CC2B53 for device EP3C25F324@1 Info: Started Programmer operation at Mon Sep 26 16:28:37 2011 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F30DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Mon Sep 26 16:28:38 2011 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 94 megabytes Info: Processing ended: Mon Sep 26 16:28:38 2011 Info: Elapsed time: 00:00:02 Info: Total CPU time (on all processors): 00:00:00 $ make Info: Building ../../bsp/hal_default/ make --no-print-directory -C ../../bsp/hal_default/ [BSP build complete] [hello_world build complete] $ nios2-download hello_world.elf There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary.
