15 years ago
alt_timestamp() issue!
I am working with Altera Stratix FPGA and NiosII processor.
In Hello_World program I wanted to check time duration using HAl API alt_timestamp() and alt_timestamp_start().
i wrote progarm like this:
# include <stdio.h># include "sys/alt_timestamp.h"# include "alt_types.h"
int main (void)
alt_u32 time1;
alt_u32 time2;
alt_timestamp_start();
time1 = alt_timestamp();
printf("hello from niosII!\n");
time2 = alt_timestamp();
printf("value =%u \n", (unsigned int) (time2-time1));
return 0;
after build it is showing following error:
Info: Linking Hello_World_0.elf
nios2-elf-g++ -T'../Hello_World_0_bsp/linker.x' -msys-crt0='../Hello_World_0_bsp/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../Hello_World_0_bsp -Wl,-Map=Hello_World_0.map -O0 -g -Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o Hello_World_0.elf obj/hello_world.o -lm
obj/hello_world.o: In function `main':
D:\Bharani_15RPM\Bharanisp_ep1s80_15rpm_15June2011_v6_50Mhz\software\Hello_World_0/hello_world.c:33: undefined reference to `alt_timestamp_start'
D:\Bharani_15RPM\Bharanisp_ep1s80_15rpm_15June2011_v6_50Mhz\software\Hello_World_0/hello_world.c:35: undefined reference to `alt_timestamp'
D:\Bharani_15RPM\Bharanisp_ep1s80_15rpm_15June2011_v6_50Mhz\software\Hello_World_0/hello_world.c:39: undefined reference to `alt_timestamp'
collect2: ld returned 1 exit status
make: *** [Hello_World_0.elf] Error 1
can anyone tell me what may be expected mistake?
Thanks in advance!
sblrde
    Did you remember to add the timer to your timestamp timer settings in the BSP/system library? I don't think it is added automatically for you so you would need to manually set it.
    I have the same problem. I've found, how to add timer to the syslib settings of nios 9.0 project.
    But how can I do the same for 11.0 project?
    Thanks in advance.
    Hey,
    If you want to add a system or timestamp timer you have to rightclick on your bsp folder in your Nios Eclipsle Project, than choose Nios2->BSP Editior
    There you can change your System Timer and Timestamp Timer
    Best regards
    Tobias
