SOkte
7 years agoAdvantages/Disadvantages of OS for testing hardware peripherals
We made a PCB design, we need to perform below tests to make sure hardware is OK. Does anyone suggest putting an OS, I believe it is too much work for just below tests. Application code does not r...
FawazJ_Altera
7 years agoHello,
You can run these tests using Nios II processor with simple C codes.
Which FPGA device are you using?
