21 years agoAddress Exception
Hi
We are using a SRAM that has a 16-bit wide data bus and /BLE and /BHE signals for byte-write. Writing bytes to addresses 0 to 7 works, with BLE and BHE behaving as expected, although A0 is always at logic 0 (so presumably we must connect A1..A18 to the SRAM). Writing words to addresses 0 to 3 is fine when the addresses are even. When the addresses are odd, though, writing $55AA to the SRAM causes 2 write cycles to consecutive addresses, BUT $55AA is presented on the data bus throughout. So writing $55AA to address 1 causes the bytes $AA,$55,$AA,$55 to appear from addresses 0 to 3, which is clearly wrong. No BLE or BHE activity appears. This reminds me very much of my 68000 days. Is there an address exception? If so this kind of "misbehaviour" could be OK if an exception is raised. The PTF file contents are below (note we're using the "dynamic bus sizing[memory]" option):## This class.ptf file built by Component Editor# 2005.06.23.15:36:32# # DO NOT MODIFY THIS FILE# If you hand-modify this file you will likely# interfere with Component Editor's ability to# read and edit it. And then Component Editor# will overwrite your changes anyway. So, for# the very best results, just relax and# DO NOT MODIFY THIS FILE#
CLASS is61lv256
ASSOCIATED_FILES
Add_Program = "the_wizard_ui";
Edit_Program = "the_wizard_ui";
Generator_Program = "cb_generator.pl";
MODULE_DEFAULTS
class = "is61lv256";
class_version = "2.0";
SYSTEM_BUILDER_INFO
Instantiate_In_System_Module = "0";
Is_Enabled = "1";
Date_Modified = "--unknown--";
Top_Level_Ports_Are_Enumerated = "1";
WIZARD_SCRIPT_ARGUMENTS
SIMULATION
DISPLAY
COMPONENT_BUILDER
GLS_SETTINGS
PORT_WIRING
SLAVE avalonS
SYSTEM_BUILDER_INFO
Bus_Type = "avalon_tristate";
Address_Width = "18";
Address_Alignment = "dynamic";
Data_Width = "16";
Has_Base_Address = "1";
Has_IRQ = "0";
Setup_Time = "10ns";
Hold_Time = "10ns";
Read_Wait_States = "20ns";
Write_Wait_States = "20ns";
Read_Latency = "0";
Maximum_Pending_Read_Transactions = "0";
Is_Printable_Device = "0";
Is_Memory_Device = "1";
Is_Readable = "1";
Is_Writable = "1";
Minimum_Uninterrupted_Run_Length = "1";
COMPONENT_BUILDER
ATS_SETTINGS
Setup_Value = "10";
Read_Wait_Value = "20";
Write_Wait_Value = "20";
Hold_Value = "10";
Timing_Units = "ns";
Read_Latency_Value = "0";
Max_Pending_Read_Transactions_Value = "1";
interface_name = "Avalon Tristate Slave";
Minimum_Arbitration_Shares = "1";
external_wait = "0";
PORT_WIRING
PORT Adds
width = "18";
width_expression = "";
direction = "input";
type = "address";
is_shared = "1";
PORT Data
width = "16";
direction = "inout";
type = "data";
is_shared = "1";
PORT WE_N
width = "1";
type = "write_n";
is_shared = "0";
PORT OE_N
width = "1";
type = "read_n";
is_shared = "0";
PORT SRAM_CE_N
width = "1";
type = "chipselect_n";
is_shared = "0";
PORT avalon_clk
width = "1";
type = "clk";
is_shared = "0";
PORT BE
width = "2";
type = "byteenable_n";
is_shared = "1";
USER_INTERFACE
USER_LABELS
name = "IS61LV256";
technology = "User Logic";
WIZARD_UI the_wizard_ui
title = "IS61LV256 - {{ $MOD }}";
CONTEXT
H = "WIZARD_SCRIPT_ARGUMENTS/hdl_parameters";
M = "";
SBI_ = "SYSTEM_BUILDER_INFO";
SBI_avalonS = "SLAVE avalonS/SYSTEM_BUILDER_INFO";
PAGES main
PAGE 1
align = "left";
title = "IS61LV256 2.0 Settings";
layout = "vertical";
TEXT
title = "Built on: 2005.06.23.15:36:32";
TEXT
title = "Class name: is61lv256";
TEXT
title = "Class version: 2.0";
TEXT
title = "Component name: IS61LV256";
TEXT
title = "Component Group: User Logic";
DEFAULT_GENERATOR
top_module_name = "";
black_box = "1";
vhdl_synthesis_files = "";
verilog_synthesis_files = "";
black_box_files = "";
COMPONENT_BUILDER
CACHED_HDL_INFO
# cached hdl info, emitted by cbGuinevereApp.CBFrameRealtime.getDocumentCachedHDLInfoSection:123
# used only by Component Builder
HDL_PARAMETERS
# generated by cbDocument.CBDocument.getParameterContainer:385
# used only by Component Editor
SW_FILES
built_on = "2005.06.23.15:36:32";
CB_GENERATOR
HDL_FILES
emit_system_h = "0";
SOPC_Builder_Version = "5.00";
}4 Replies
is your wiring correct ?
i use ISSI IS61LV25616AL 256k x 16 wiring: NIOS [A18..A1] -> SRAM [A17..A0] userlogic is setup as following: Bus Interface Type: Avalon Memory Slave PORT NAME | Width | Direction | Shared | Type address | 18 | input | yes | address write_n | 1 | input | yes | write_n read_n | 1 | input | yes | read_n writedata | 16 | inout | yes | data chipselect_n | 1 | input | --- | chipselect_n be_n | 2 | input | yes | byteenable_n system clock frequency is 50 Mhz i use 1 setup, 1 wait, 1 wait cycle - Altera_Forum
Hi Jason,
> Writing words to addresses 0 to 3 is fine when the addresses are even. When the > addresses are odd, though, ... Don't do this -- writing a halfword to an odd address results in and undefined operation. Take a look at the instruction set for details. > Is there an address exception? No. Regards, --Scott - Altera_Forum
Could I make this (addition of Address Exception) a formal change request to Altera, please?
Hi Jason,
> a formal change request to Altera You should probably do this at the Altera website. Regards, --Scott
