15 years agoAdding a custom component
Hi all, I am new to Nios and embedded designing. I have the design files for Nios-II system built for Nios development kit 1C20. I obtained this system from Altera. I want to edit this system u...
15 years agoHi Supal,
Thank you very much for the response. You have understood my requirement correctly. But the solution you have provided is not elaborate. I have worked on FPGA logic design, but I am new to embedded design. I am pretty conversant with Quartus tool, but am new to SOPC. I want to know how I can do the mapping using SOPC builder. I want to know how I can create the enable signal using some software instruction. Do I need to use the Avalon bus. These are the things I need to know. I want to know the procedure. Is there some tutorial on creating custom components using SOPC builder. The user guide is not of much help. regards, rajesh
