12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
10 years ago --- Quote Start --- The FPGA module I have developed has an Altera Avalon MM master which is connected to the AXI port FPGA2HPS, the port that your FPGA design has is an AXI or Avalon port? --- Quote End --- It's Avalon MM master too. At least one test case just used Altera's modular SGDMA connected to f2h_axi_slave.
