12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
10 years agoThanks for your reply.
I have a working system, using yocto I can build the bootloader, kernel image, device tree and the file system. Is the GnuRadio ACP port configuration similar for the Altera devices? I have configures the AXI port attributes as you said and also sending to the HDL module the physical address | 0x80000000, but I am getting a kernel panic after starting writing to that memory location, did you configure something for the ACP port before using it?
