15 years agoAchieving higher performance?
Hello i want to make my design as fast as possible to run uCLinux, my software is running at 40ms and should run at 8ms. I am using a linux with MMU, 50mhz clock, 32k Data and instruction Cache...
15 years agoOh, important:
You need to ajust not only the clock period in the .SDC but you also need to make sure the clock frequency settings are correct in any components that have them (ie, PLLs, SDRAM controller, etc).
