15 years agoAchieving higher performance?
Hello i want to make my design as fast as possible to run uCLinux, my software is running at 40ms and should run at 8ms. I am using a linux with MMU, 50mhz clock, 32k Data and instruction Cache...
15 years agoHow can i compile with -O2 or -O3 using MMU Linux DSL?
And i have a sdram on my design (DE2-70 board) and it's running at 100mhz while my NIOS is at 50mhz. If i try to raise my NIOS clock i get either failed to verify, 00ps kernel not syncing or when i type nios-2terminal nothing shows error. I also tried to add a float point unit at Qsys and enable hardware divide but it didnt made a big difference. My code do mainly float point operations and some i/o
