14 years agoaccess to every address of SDRAM
I have a problem with reading and writing data on SDRAM, I need to access every address of SDRAM, this is my C code written for Nios: # include <stdio.h> # include <io.h> # define BASE_SDR...
14 years agoCheck that you are reading the correct value. In both your access methods, 6000 means that you are reading the 6000th *word* in the SDRAM, and words are defined as 32 bits, with both the IORD macro and the int pointer. So you are in fact reading addresses 0x805dc0 - 0x805dc3 (0x80000 + (6000 * 4))
Also remember that IORD bypasses the cache while the pointer access doesn't, so if this memory area is in the CPU's cache you can have different results between the two accesses.
