hi hippo
I already add "init=/init" in kernel command line that meet the same problem ,again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 rootfstype=jffs2 init=/init PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data) Mount-cache hash table entries: 512 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc. io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 1 MTD partitions on "Altera NDK flash (AMD)": 0x00000000-0x00400000 : "jffs2" usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. VFS: Mounted root (jffs2 filesystem) readonly. Freeing unused kernel memory: 44k freed (0x938000 - 0x942000) Warning: unable to open an initial console. Failed to execute /init. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel[/b] --- Quote End --- Thx in advance ! - Altera_Forum
the "init= " is not needed.
Try initramfs again, and mount the jffs2 to /mnt Check if you have /mnt/init, which is sym-link. if you do not have it, copy it again. mount -t jffs2 /dev/mtdblock0 /mnt cd /mnt ls -l cp -a /init . cd / umount /mnt Config kernel command line "root=/dev/mtdblock0 rw rootfstype=jffs2" - Altera_Forum
--- Quote Start --- originally posted by hippo@Jun 1 2006, 08:39 AM the "init= " is not needed.try initramfs again, and mount the jffs2 to /mnt
check if you have /mnt/init, which is sym-link.
cd /mnt
ls -l
cp -a /init .
cd /
umount /mnt
config kernel command line "root=/dev/mtdblock0 rw rootfstype=jffs2"
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15764)
--- quote end ---
--- Quote End --- hi hippo I can find "init" in mnt dir on uclinux. <div class='quotetop'>QUOTE </div> --- Quote Start --- BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls -l lrwxrwxrwx 1 root root 10 Nov 29 17:02 init -> /sbin/init # cd /# umount /mnt# [/b] --- Quote End --- Why i disable initramfs patch to empty that can not boot kernel successfully for every time ? and how to do that next step ? Thx !!!!!!!!!!
It looks like your jffs2 contains only the init link, but where are other dirs?
--- Quote Start --- originally posted by hippo@Jun 1 2006, 08:10 PM it looks like your jffs2 contains only the init link, but where are other dirs?<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15779)
--- quote end ---
--- Quote End --- hi hippo sorry , i forgot to copy some dirs to mnt dir on uclinux. 1.i use initramfs and kernel command line is "root=/dev/mtdblock0 rw rootfstype=jiffs2". <div class='quotetop'>QUOTE </div> --- Quote Start --- # mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls# mkdir proc sys var tmp mnt# cp -a /init /etc /dev /bin /sbin /lib /usr /root /home .# ls bin etc init mnt root sys usr dev home lib proc sbin tmp var# pwd /mnt# umount /mnt umount: Couldn't umount /mnt: Inappropriate ioctl for device# cd /# umount /mnt# [/b] --- Quote End --- 2. i don't use initramfs and prebuild some dir in /rootfs/mnt dir . such as /proc /bin /home ... <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 rw rootfstype=jiffs2 init=/initPID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data) Mount-cache hash table entries: 512 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc. io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 1 MTD partitions on "Altera NDK flash (AMD)": 0x00000000-0x00400000 : "jffs2" usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. VFS: Cannot open root device "mtdblock0" or unknown-block(31,0) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b] --- Quote End --- How to do that next step ? Thx !
--- Quote Start --- Kernel command line: root=/dev/mtdblock0 rw rootfstype=jiffs2 init=/init[/b] --- Quote End --- You have a typo, it should be jffs2 . - Altera_Forum
hi hippo
I don't use initramfs and not find init from booting messages.now when i use initramfs that can execute command on linux, and can mount mtdblock to /mnt dir. but no init in /mnt dir <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 rw rootfstype=jffs2 init=/init PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data) Mount-cache hash table entries: 512 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc. io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 1 MTD partitions on "Altera NDK flash (AMD)": 0x00000000-0x00400000 : "jffs2" usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. VFS: Mounted root (jffs2 filesystem). Freeing unused kernel memory: 44k freed (0x938000 - 0x942000) Warning: unable to open an initial console. Failed to execute /init. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel.[/b] --- Quote End --- When i don't use initramfs why can not find init from boot messages ? THx ! - Altera_Forum
The key point is that you need a full rootfs on you jffs2 drive.
One way to do it is using mkfs.jffs2 on your Linux host. But we use another approach here, we copy them from initramfs. When you use initramfs, you should not have root=/dev/mtdblock0 in the kernel command string. try "cat /proc/mounts" . When you use jffs2 for root, you should not use initramfs. You don't need the "init=/init" in kernel command string. Just "root=/dev/mtdblock0 rw rootfs=jffs2" should be enough. Now check again if you have the proper rootfs in the jffs2 drive. boot with initramfs, mount the jffs2 drive, and "ls -l" to get its content. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jun 2 2006, 06:09 AM the key point is that you need a full rootfs on you jffs2 drive.one way to do it is using mkfs.jffs2 on your linux host. but we use another approach here, we copy them from initramfs.
when you use initramfs, you should not have root=/dev/mtdblock0 in the kernel command string. try "cat /proc/mounts" .
when you use jffs2 for root, you should not use initramfs.
you don't need the "init=/init" in kernel command string.
just "root=/dev/mtdblock0 rw rootfs=jffs2" should be enough.
now check again if you have the proper rootfs in the jffs2 drive.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15796)
--- quote end ---
--- Quote End --- hi hippo Thank u ! When i mount mtdblock0 to /mnt dir that can see some dir in there. 1. I use initramfs and no kernel command string <div class='quotetop'>QUOTE </div> --- Quote Start --- # mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls -l drwxr-xr-x 2 500 500 0 Nov 29 17:00 bin drwxr-xr-x 6 root root 0 Nov 29 17:00 dev drwxr-xr-x 4 500 500 0 Nov 29 17:00 etc drwxr-xr-x 3 500 500 0 Nov 29 17:00 home lrwxrwxrwx 1 root root 10 Nov 29 17:02 init -> /sbin/init drwxr-xr-x 2 500 500 0 Nov 29 17:00 lib drwxr-xr-x 2 root root 0 Nov 29 17:01 mnt drwxr-xr-x 2 500 500 0 Nov 29 17:00 opt drwxr-xr-x 2 root root 0 Nov 29 17:01 proc drwxr-xr-x 2 500 500 0 Nov 29 17:00 root drwxr-xr-x 2 500 500 0 Nov 29 17:00 sbin drwxr-xr-x 2 root root 0 Nov 29 17:01 sys drwxr-xr-x 2 root root 0 Nov 29 17:01 tmp drwxr-xr-x 2 root root 0 Nov 29 17:01 var# cd /# umount /mnt# [/b] --- Quote End --- 2. I don't use initramfs and have "root=/dev/mtdblock0 rw rootfs=jffs2" kernel command string <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 rw rootfs=jffs2 PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6768k/8192k RAM, 0k/0k ROM (1185k kernel code, 144k data) Mount-cache hash table entries: 512 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub JFFS2 version 2.2. (NAND) © 2001-2003 Red Hat, Inc. io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 1 MTD partitions on "Altera NDK flash (AMD)": 0x00000000-0x00400000 : "jffs2" usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)[/b] --- Quote End --- finally , I can't boot the kernel ....... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Why ? Thx !
One minor problem in your rootfs, the uid/gid of bin etc... is 500/500, which is incorrect.
If your user id and group id on Linux are not 500, change these to your id instead. This will be used to map user file/dir ownership to root in initramfs. General setup --> (for new kernels) OR Device Drivers --> Block devices --> (for 2.6.11-uc0) (500) User ID to map to 0 (user root) (500) Group ID to map to 0 (group root) Add a dir /root to jffs2. Then rebuild the kernel. And make the jffs2 rootfs data again.
