9 years agoA10 HPS not booting from micro SD card - NRST pulsing
Hello, I have a custom A10 prototype PCB, and I'm trying to bring up the HPS. I am building the preloader/uboot using the BSP-Editor and writing the output to a partition on a micro sdcard (sa...
9 years ago --- Quote Start --- I am able to program my .sof file through JTAG and when SD card has the HPS related binary files(u-boot generated by BSP editor). I am able to see that HPS DDR is calibrated successfully. But when i convert the .sof into .rbf and load it along with the u boot files, my final state is emif_reset interrupt is acknowledged (appears 3 times) and hence HPS DDR calibration fails. How do I debug this issue? --- Quote End --- Can you load the FPGA manually during uboot stage? We're still trying to get uboot to come up. We have a non-standard uboot process which works when we put it on the dev kit QSPI, but so far hasn't worked when putting it on the sd card.
