8 years agoA10 HPS boot speed QSPI vs eMMC
For a typical HPS first, boot from flash boot flow which flash is faster to boot from, QSPI or eMMC? Assumed that all the bloat is trimmed from Angstrom. Boot from NAND flash is not an option as I don't want to loose UART during boot.
QSPI interface is 104 MHz, 4 bit and has no init sequence, I believe. 256 MByte seems to be the biggest available. eMMC interface is 50 MHz, 8 bit and requires a long init sequence. DDR doesn't seem to be supported. Up to 64 GByte currently available. Has anybody experience with this? Is the a difference in power consumption? Any other points to consider when choosing between these two?No RepliesBe the first to reply
