15 years ago64bit ddr2 conflit with lan91c11
Hello in my design, I use a ddr2 high performance controller, DQ is 32bits, so local interface is 64 bit. and I also use a lan91c11. before generation, there is no any base address conflict. b...
15 years agoDoesn't the issue get solved when you use the auto assign base address menu item? If not you can try and give addresses manually to the ddr controller and the lan chip.
