15 years ago2 Leds -> how many PIO?
Hi all, I'm writing a simple program on interrupt behaviour, with an interval timer (that generate timer interrupt and its handler make a ledg blink) and an hardware interrupt generated by a bu...
15 years agook, you can try with this macro
# define SET(x,val) { unsigned char in_led=IORD_ALTERA_AVALON_PIO_DATA(X_BASE); unsigned char out_tmp=1<<x; unsigned char out; if(val==1){ out=in_led | out_tmp; } else{ out=in_led &(~out_tmp); } IOWR_ALTERA_AVALON_PIO_DATA(X_BASE , out );\ } if you want set in 1, only put the macro in your code like the following SET(0,1)// put in 1 the led 0 SET(1,1)// put in 1 the led 1 SET(0,0)// put in 0 the led 0 SET(1,0)// put in 0 the led 1 or if you want toggle macro, try this # define TOGGLE_LED(x) { unsigned char in_led=IORD_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE); unsigned char out_tmp=1<<x; unsigned char out=in_led ^ out_tmp; IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE , out);\ }
