22 years ago1S10 dev. board and MAX Freq.
Hello, I would like to know if we can increase the FMax of the board. I would like to reach the MAX frequency can support the board. How can I do it? The reference design has implemented...
22 years ago --- Quote Start --- originally posted by badomen@Aug 11 2004, 02:41 PM is there some quartus optimization that i should try since my target is 100mhz, and i was able to make the "s" model keep up to the full one (i want to save 400les) --- Quote End --- Turn on restructure multiplexers in analysis and synthesis settings. If it is set to 'Auto' it is probably turned off. It will save you a whole load of LE's, but there is a small risk of increasing f_max slightly (which is why it is off by default).
