19 years ago16 bit SRAM
Dear all, I have a problem that is maybe already seen by one of you: I have generated a NIOS core with a 256Kx16 bit SRAM interface. The SRAM module is connected to the avalon tri-state br...
19 years ago --- Quote Start --- originally posted by karel van haver@Dec 1 2006, 12:07 PM dear all,
i have a problem that is maybe already seen by one of you:
i have generated a nios core with a 256kx16 bit sram interface. the sram module is connected to the avalon tri-state bridge.
address = (0-17)
data = (0-15)
wrn = 1 bit
rdn = 1 bit
csn = 1 bit
bhen=1 bit
blen = 1 bit
the generation of the nios core completes without errors. but after i have finished my design fitting .. i get following warning
sram_address(0) is synthezised away
any idea why?... is the address mapping between the avalon bridge and the sram module wrong?
regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19768)
--- quote end ---
--- Quote End --- Read the building memory subsystems (http://www.altera.com/literature/hb/qts/qts_qii54006.pdf) section in the SOPC Builder handbook. Look at table 9-1... You're welcome to either modify the existing Europa-based (Perl HDL generation) SRAM component or generate your own using the Component Editor/Builder. Best Regards, - slacker
