RWeiz
7 years ago想要NIOS 硬體跟軟體 燒死再FPGA裡面 到最後一步的時候,出現了ERROR。
Error: No EPCS layout data - looking for section [EPCS-9D6017] Error: Unable to use EPCS device Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_...
Ahmed_H_Intel1
7 years agoAttached is the step by step guide of how to use the JIC programming procedure
Please follow this to get the issue resolved.
If you still insist to use the NIOS II flash programme, I suggest the following solution:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03212006_29.html?GSA_pos=591&WT.oss_r=1&WT.oss=io
