RWeiz
7 years ago想要NIOS 硬體跟軟體 燒死再FPGA裡面 到最後一步的時候,出現了ERROR。
Error: No EPCS layout data - looking for section [EPCS-9D6017] Error: Unable to use EPCS device Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_...
Ahmed_H_Intel1
7 years agoHello,
Can you please use the (.jic) JTAG Indirect Configuration procedure instead of the NIOS II flash programmer?
I will attach the step by step guide to tell you how to use the (jic) procedure. The NIOS II flash programmer I never recommend.
