Dde_B
7 years agoWhy won't PLL Reconfig IP allow access to cascaded tap?
So, I have created a PLL with a 50MHz clk in. From there I generate two clocks. C0 = 100MHz, and C1 is 100KHz. The PLL achieves these values by having an M = 12, N=1 and a C0 counter of 6 for t...
SreekumarR_G_Intel
7 years agoHello , Ah you are using max 10 . Yeah I agree Post scale counter cascading not possible as per user guide.Here is the link below ,Refer page 31/67.
Thank you ,
Sree
